What wriers are + and _ on the dmm
what wriers are + and _ on the dmm
In DCAClab Circuit Simulator, the Digital Multimeter (DMM) has three probes:
1. Red Probe for Voltage/Resistance (VΩ):
  • Used to measure voltage across two points or resistance.
  • Connect this red probe in parallel with the component.
2. Red Probe for Current (A):
  • Used to measure current flowing through a component.
  • Must be connected in series in the circuit.
3. Black Probe (COM):
  • The black probe is common for measuring both voltage and ampere.
  • Always connect this probe to the reference point (usually ground or return path).
