Todo conectado en una protonoard
IMG-20250506-WA0005
The image shows a circuit using an IC 555 timer in bistable mode (flip-flop mode). This means it can stay in either ON or OFF state until triggered by a button.
Circuit Explanation:
  • IC 555 is configured in bistable mode:
    • The ON button connects pin 2 (trigger) to ground when pressed. This causes pin 3 (output) to go HIGH, turning ON the red LED.
    • The OFF button connects pin 4 (reset) to ground when pressed. This resets the IC, making pin 3 (output) go LOW, turning OFF the red LED and ON the blue LED (assuming the blue LED is connected to positive voltage through a resistor).
LEDs:
  • Both LEDs have current-limiting resistors.
  • The red LED lights up when the output is HIGH.
  • The blue LED lights up when the output is LOW (if connected to Vcc through the output).
Yes, it can easily be built on a breadboard. You’ll need:
  • One 555 timer IC
  • Two Normal Switches instead of push buttons
  • Two LEDs (red and blue)
  • Three resistors for LEDs (around 220–330 ohms)
  • One power supply (like 5V)
  • One Capacitor
  • A breadboard and jumper wires
If you want to learn, please you can visit https://dcaclab.com/en/experiments/80200-bistabe-mode-using-555-timer
