RC and RL Circuit Transient Response in DCAClab
Transient response is the temporary reaction of a circuit immediately following a sudden change such as flipping a switch, changing a voltage source, or connecting a component.
RC Transient Response: The temporary period where a capacitor charges or discharges its voltage exponentially through a resistor. It resists sudden changes in voltage, governed by the time constant,
τ = RC
RL Transient Response: The temporary period where an inductor builds up or decays its current exponentially through a resistor. It resists sudden changes in current, governed by the time constant,
τ = L/R.
In both cases, the transient phase is the bridge between turning a switch on/off and the circuit reaching a stable steady state (5 * τ).
RC Circuit - Switch ON (Charging State)
At the instant the switch is turned ON (t=0), the capacitor is completely uncharged, acting like a short circuit. Therefore, the capacitor voltage (vC) starts at zero, while the circuit current (i) jumps to its maximum value. As time progresses, the capacitor accumulates charge, causing its voltage to exponentially increase toward the source voltage (Vs), while the circuit current exponentially decays to zero (acting as an open circuit in steady state).
Time Constant Milestone (1τ): At exactly one time constant (τ = RC), the capacitor voltage reaches 63.2% of its maximum value, and the current drops to 36.8% of its initial maximum value.
[Graph 1: RC Charging - vC(t) starts at 0 and curves up to 1; i(t) starts at 1 and curves down to 0 over 5 time constants]
RC Circuit - Switch OFF (Discharging State)
When the switch is turned OFF (or the source is disconnected), the fully charged capacitor acts as a temporary voltage source. It begins releasing its stored energy through the resistor, causing the current to flow in the opposite direction. Consequently, the capacitor voltage exponentially decays from its maximum value down to zero, and the circuit current also decays back to zero from the negative side.
Time Constant Milestone (1τ): At exactly one time constant, both the discharging voltage and the reverse current decay down to 36.8% of their initial values at the moment of switch-off.
[Graph 2: RC Discharging - vC(t) starts at 1 and curves down to 0; i(t) starts at -1 and curves up to 0 over 5 time constants]
RL Circuit - Switch ON (Inductor Current Growth State)
An inductor inherently opposes any sudden change in current (Lenz’s Law). At the instant the switch is turned ON, the inductor generates a strong counter-electromotive force (back EMF) to oppose the rising current, acting like an open circuit. Thus, initially, the inductor voltage is at its maximum, and the current is zero. As the magnetic field establishes, the opposition drops, causing the current to exponentially grow to its maximum value, while the inductor voltage gradually drops to zero (acting like a short circuit in steady state).
Time Constant Milestone (1τ): At exactly one time constant (τ = L/R), the inductor current rises to 63.2% of its maximum steady-state value, and the inductor voltage decays to 36.8% of the source voltage.
[Graph 3: RL Growth - i(t) starts at 0 and curves up to 1; vL(t) starts at 1 and curves down to 0 over 5 time constants]
RL Circuit - Switch OFF (Inductor Current Decay State)
When the switch is turned OFF, the current attempts to drop to zero instantly. To oppose this sudden collapse, the inductor releases its stored magnetic field energy to maintain the current flow in the same direction. As a result, the circuit current exponentially decays from maximum to zero. To achieve this, the inductor induces a sudden negative voltage spike, which exponentially decays back up to zero as the magnetic field fully dissipates.
Time Constant Milestone (1τ): At exactly one time constant, the decaying current drops to 36.8% of its initial maximum value, and the negative voltage spike decays back toward zero, reaching -36.8% of its peak negative value.
[Graph 4: RL Decay - i(t) starts at 1 and curves down to 0; vL(t) starts at -1 and curves up to 0 over 5 time constants]
Conclusion:
The laboratory experiment successfully demonstrates the transient behavior of RC (Resistor-Capacitor) and RL (Resistor-Inductor) circuits under both Switch ON and Switch OFF conditions. The experimental data confirms that neither circuit shifts instantly between states; instead, they experience an exponential transition period governed by their respective time constants (τ = RC for the RC circuit, and τ = L/R for the RL circuit).
