Q1. Simulate the given circuit on any simulator to measure the total current, and current passing through each resistor, measure voltage across each resistor, and provide snaps for all measurements.(Submit the assignment in print form).
Resistance values will be: For example SID: 12312. Replace 0 with 1.
• R1= (1st value of SID) kohms Hint: 1kohm.
• R2= (last 3 digits of SID) ohm. Hint: 312ohm.
• R7= (2nd value of SID) kohms. Hint: 2kohm.
• R3= R8= (1st two values of SID) ohm. Hint: 12ohm.
• R4= R11= (1st three digits of SID) ohm Hint: 123ohm.
• R5= R9= (last digit of SID) kohm. Hint: 2kohm.
• R6= R10= (2nd last digit of SID) kohm. Hint: 1kohm.
• Resistance values will be: For example SID: 12312. Replace 0 with 1.
@muhammadyaseenbugti3 thanks for your post, but the description is not sufficient without a diagram to know how resistors are connected to each other…
