Ngspice Ultimate Master Command Reference Guide
Domain Classified, Hierarchical, & Universal — Complete & Rigorous Reference with Practical Netlist Examples
  • Author: Md. Anisur Rahman
  • Role: Subject Matter Expert (Electronics Simulation Analyst) at DCAClab Circuit Simulator
  • Compatibility: NGSPICE v40+ Compatible
Overview
This master guide covers all fundamental and advanced ngspice commands classified into four core domains:
  1. Simulation & Analysis
  2. Component Models & Hierarchy
  3. Automation & Interactive Control
  4. Simulator Options & System Directives
DOMAIN 1: SIMULATION & ANALYSIS COMMANDS
.ac — Small-Signal AC Frequency Response Analysis
Calculates the AC frequency response of a linear or linearized circuit over a specified frequency range. Computes magnitude, phase, real, and imaginary components of node voltages and branch currents.
  • Syntax:
    .ac <variation_type> <n_points> <fstart> <fstop>
  • Examples:
    .ac dec 20 10 1MEG
    .ac lin 1000 1kHz 10kHz
  • Parameters:
    • dec: Logarithmic sweep per decade (20 points per decade from 10 Hz to 1 MHz).
    • lin / oct: Linear sweep or octave sweep (points per octave).
  • Applications: Bode plot generation, filter cutoff frequency, amplifier bandwidth, resonant frequency response.
.dc — Direct Current (DC) Sweep Analysis
Sweeps independent DC voltage or current sources (or temperature/parameters) to determine the static DC transfer characteristics of a circuit.
  • Syntax:
    .dc <srcname> <vstart> <vstop> <vstep> [<src2> <vstart2> <vstop2> <vstep2>]
  • Examples:
    .dc VIn 0 5 0.01
    .dc VDS 0 5 0.1 VGS 1 3 0.5
  • Parameters:
    • Primary Source (VIn): Sweeps VIn from 0V to 5V in increments of 0.01V.
    • Nested Sweep (VDS / VGS): Generates a family of MOSFET $I$-$V$ curves by sweeping VDS for each step of VGS.
  • Applications: Transistor $I$-$V$ curves, diode forward characteristics, inverter voltage transfer characteristics (VTC).
.tran — Transient Time-Domain Analysis
Computes time-domain response of non-linear circuits subject to time-varying input signals (pulse, sine, piecewise linear).
  • Syntax:
    .tran <tstep> <tstop> [<tstart> [<tmax>]] [uic]
  • Examples:
    .tran 0.1n 100n 0 0.5n uic
  • Parameters:
    • tstep (0.1n): Suggested printing step size.
    • tstop (100n): Total simulation stop time.
    • uic (Use Initial Conditions): Bypasses default Operating Point (.op) calculation and uses user-defined node initial conditions (.ic).
  • Applications: Propagation delay, switching transients, oscillator startup, power supply ripple.
.op — DC Operating Point Analysis
Calculates the static DC operating point (bias point) of the circuit with inductors shorted, capacitors opened, and independent AC/transient sources set to zero.
  • Syntax:
    .op
  • Function: Solves non-linear system equations to compute all node voltages, source currents, and semiconductor device bias parameters ($V_{gs}$, $V_{ds}$, $I_c$, $g_m$, $r_\pi$).
  • Applications: Amplifier biasing check, static power dissipation analysis.
.noise — Small-Signal Noise Analysis
Calculates total integrated noise and spectral noise density at an output node generated by circuit components (thermal noise, shot noise, flicker $1/f$ noise).
  • Syntax:
    .noise V(out) <srcname> <pt_type> <pts> <fstart> <fstop> [<summary_interval>]
  • Examples:
    .noise V(out) VIn dec 10 10 1MEG 1
  • Parameters:
    • V(out): Output node where equivalent output noise is calculated.
    • VIn: Input reference source for calculating Equivalent Input Noise.
  • Applications: Low-Noise Amplifier (LNA) design, SNR evaluation, noise figure estimation.
.four — Fourier Distortion Analysis
Performs a Fourier analysis on transient simulation results to calculate fundamental frequency component, harmonic amplitudes, and Total Harmonic Distortion (THD).
  • Syntax:
    .four <fund_freq> <ov_var1> [<ov_var2> ...]
  • Examples:
    .four 1kHz V(out)
  • Parameters:
    • fund_freq (1kHz): Fundamental frequency of the periodic transient waveform.
  • Output: Computes DC component, 1st through 9th harmonics, relative magnitude, phase, and % THD.
  • Applications: Audio power amplifier linearity, harmonic distortion in power electronics.
.sens — DC/AC Small-Signal Sensitivity Analysis
Calculates the sensitivity of an output node voltage or branch current with respect to circuit device parameters (resistances, capacitances, device dimensions).
  • Syntax:
    .sens <outvar> [ac <dec|lin|oct> <pts> <fstart> <fstop>]
  • Examples:
    .sens V(out)
    .sens V(out) ac dec 10 100 100kHz
  • DC Sensitivity: Evaluates $\frac{d(V_{out})}{dR_1}$, identifying dominant component tolerances affecting bias points.
  • Applications: Component tolerance optimization, yield analysis, critical component identification.
.tf — Small-Signal Transfer Function Analysis
Computes the DC small-signal transfer function (gain), input impedance, and output impedance of a circuit.
  • Syntax:
    .tf <outvar> <insrc>
  • Examples:
    .tf V(out) VIn
  • Returns: Small-signal voltage gain $\frac{V_{out}}{V_{in}}$, input resistance $R_{in}$ at source VIn, and output resistance $R_{out}$ at node out.
  • Applications: Operational amplifier gain-stage sizing, impedance matching.
.pz — Pole-Zero Analysis
Computes the poles and zeros of the small-signal AC transfer function in the complex $s$-plane ($s = \sigma + j\omega$).
  • Syntax:
    .pz <node1> <node2> <node3> <node4> <vol|cur> <pz|pol|zer>
  • Examples:
    .pz 1 0 2 0 vol pz
  • Nodes: Input nodes (1,0) and output nodes (2,0).
  • vol pz: Voltage transfer function ($\frac{V_{out}}{V_{in}}$); computes both poles and zeros.
  • Applications: Feedback amplifier stability, phase margin optimization, root locus determination.
.disto — Small-Signal Distortion Analysis
Computes small-signal harmonic and intermodulation distortion components under multi-frequency AC excitation.
  • Syntax:
    .disto <variation> <pts> <fstart> <fstop> [<f2overf1>]
  • Examples:
    .disto dec 10 1kHz 1MEG 0.9
  • Output: Analyzes 2nd and 3rd harmonic distortion ($2f_1, 3f_1$) and intermodulation products ($f_1 \pm f_2$).
  • Applications: High-fidelity RF mixing analysis and low-distortion preamplifier design.
.measure / .meas — Automatic Data Extraction Command
Evaluates custom metrics (rise time, peak-to-peak voltage, bandwidth, propagation delay, duty cycle) from simulation output vectors.
  • Syntax Examples:
    .meas tran v_pp PP V(out)
    .meas tran t_delay TRIG V(in)=2.5 RISE=1 TARG V(out)=2.5 FALL=1
    .meas ac bw WHEN vdb(out)=-3
  • Parameters:
    • v_pp: Calculates peak-to-peak amplitude of V(out).
    • t_delay: Measures time delay between 1st rising edge of V(in) at 2.5V and 1st falling edge of V(out) at 2.5V.
    • bw: Finds frequency where gain drops by -3dB.
DOMAIN 2: COMPONENT MODELS, PARAMETERS & HIERARCHY
.ic — Set Initial Conditions
Sets explicit initial voltage levels for nodes or initial currents for inductors at time $t=0$ for transient analysis.
.ic V(out)=0 V(nodeA)=3.3 L1#branch=1.0m
Forces node out to start at 0V and nodeA to start at 3.3V during .tran with the uic flag.
.nodeset — Specify Initial Node Voltage Guesses
Provides initial voltage hints to aid the Newton-Raphson convergence algorithm for difficult DC operating point calculations.
.nodeset V(bias)=1.2 V(net12)=2.5
Note: Unlike .ic, .nodeset is used as a solver initial guess and releases control once the iterative convergence succeeds.
.param — Parameter Definition & Expressions
Defines global circuit variables and dynamic mathematical expressions evaluated prior to simulation execution.
.param Rin=1k Rf=10k Gain={1 + (Rf/Rin)}
R1 in out {Rin}
Allows dynamic parameter sweeps, parameterized netlist blocks, and expression-based sizing.
.include — External File Inclusion
Imports external SPICE files, model libraries, subcircuits, or netlists into the current simulation context.
.include "./models/opamp.lib"
.include "555_timer.cir"
.lib — Library Inclusion / Definition
Includes specific corner models (e.g., Fast-Fast, Slow-Slow, Typical) from a structured model library file.
.lib "tsmc180nm.lib" TT_CORNER
.subckt / .ends — Subcircuit Block Definition
Defines reusable hierarchical macro-blocks (op-amps, logic gates, sub-modules) with local node scoping.
.subckt INVERTER in out vdd gnd Wn=1u Wp=2u
M1 out in gnd gnd NMOS W={Wn} L=0.18u
M2 out in vdd vdd PMOS W={Wp} L=0.18u
.ends INVERTER
.model — Semiconductor Device Model Definition
Defines physical parameter sets for semiconductor components (Diode, BJT, MOSFET, JFET).
.model NPN_GENERIC NPN (IS=1e-14 BF=100 VAF=100 CJE=2pF)
.model 1N4148 D (IS=2.52n RS=0.568 N=1.752 BV=100 IBV=10u)
DOMAIN 3: AUTOMATION, SCRIPTS & TERMINAL CONTROL
.control / .endc — Interactive Scripting Engine
Encapsulates interactive ngspice scripting commands (loops, conditional logic, dynamic sweeps, custom plotting, parameter tuning).
.control
  run
  let temp_var = 25
  while temp_var <= 100
    set temp = $temp_var
    tran 0.1n 50n
    let temp_var = temp_var + 25
  end
  plot V(out)
.endc
.print & .plot — Legacy Numerical Logging and ASCII Plotting
  • .print: Forces numerical tabular output logging to standard output or file.
  • .plot: Renders legacy interactive ASCII character plots directly in terminal windows.
.print tran V(out) I(VIn)
.plot tran V(out) V(in)
.save & .probe — Simulation Data Storage Options
  • .save: Restricts data saving strictly to specified node vectors (drastically reduces RAM usage and output binary file size).
  • .probe: Saves specific voltages and currents for external post-processors (e.g., Rawfile/Nutmeg format).
.save V(out) V(in) @m1[id]
.probe V(1) I(VIn)
.end — Absolute End of Netlist File
Mandatory terminal line required at the absolute end of every SPICE netlist file. Lines following .end are ignored by the parser.
.end
DOMAIN 4: SIMULATOR & SYSTEM OPTIONS
.options — Numerical Solver Tolerance Controls
Configures internal numerical integration, matrix solver options, and error tolerance thresholds.
.options RELTOL=0.001 ABSTOL=1pA VNTOL=1uV PIVOT=1 GMIN=1e-12 METHOD=gear
.title High-Speed Differential Amplifier AC/Transient Master Deck
MASTER EXAMPLE: COMPLETE COMPREHENSIVE NETLIST
The following standalone netlist combines subcircuit hierarchy, component modeling, parameter pass-through, transient, AC, Fourier, and automated data measurement:
.title Master Complete SPICE Reference Circuit Demo
* Include Models (if external)
*.include models.inc
* Parameters
.param VDD_VAL=5.0 R_LOAD=2k
* Power Supply and Input Signal
VDD vdd 0 DC {VDD_VAL}
VIn in 0 DC 0 AC 1 SIN(0 0.1 1kHz)
* Subcircuit Block Call
X1 in out vdd 0 GainBlock Rload={R_LOAD}
* Subcircuit Definition
.subckt GainBlock input output vcc gnd Rload=1k
  C1 input bias 10u
  R1 vcc bias 100k
  R2 bias gnd 22k
  Q1 collector bias emitter NPN_MODEL
  RC vcc collector 4.7k
  RE emitter gnd 1k
  CE emitter gnd 100u
  C2 collector output 10u
  RL output gnd {Rload}
.ends GainBlock
* Component Model
.model NPN_MODEL NPN (IS=1e-14 BF=150 VAF=100)
* Initial Condition and Node Guess
.nodeset V(X1.bias)=0.9
.ic V(out)=0
* Simulation Commands
.op
.tran 10u 5m
.ac dec 20 10 1MEG
.four 1kHz V(out)
* Automated Measurement Commands
.meas tran vpeak MAX V(out)
.meas ac max_gain MAX vdb(out)
* Control Script Block
.control
  run
  plot V(in) V(out)
  plot vdb(out)
.endc
.end
If you need pdf about the topics, please visit pdf page link below-
Smart Master Ngspice Command Guide PDF
