Electronic Forum
Looks like the bridge rectifier doesn’t work right? The diagram is right but the “+” is outputting the negative voltage.
Thanks for catching this! You were right: when a bridge rectifier was added to a circuit saved before mid-November, its + and − outputs were swapped. We’ve fixed it in today’s update, so + now gives the positive voltage in every circuit, in both the standard simulator and NGSpice mode. Please reload the page to get it. If you had wired a bridge the other way round to work around this, flip it back.
