como veo la velocidad del ventilador?
To check the fan speed, you can use a potentiometer and a digital multimeter (DMM) in a simple circuit.
Here’s how:
Use a Potentiometer
- Connect the potentiometer in series with the fan and power supply.
- Turning the potentiometer knob changes the voltage going to the fan, which controls the speed.
Measure Voltage with a DMM
- Set your DMM to DC voltage mode.
- Place the probes across the fan terminals.
- As you turn the potentiometer, watch the voltage change.
- Higher voltage = faster fan speed, lower voltage = slower speed.
Note: This gives you indirect control and measurement of fan speed.
If you need the exact RPM, you’ll need a tachometer or a fan with a speed sensor wire (usually yellow or blue in PC fans).
