Circuito telégrafo eléctrico
Alguien podría explicarme el funcionamiento del circuito eléctrico? Y realizarlo?
:magnifying_glass_tilted_left: What is an Electric Telegraph?
An electric telegraph is a communication system that sends messages using electrical signals. It was one of the first long-distance communication devices, and it worked by sending pulses of electricity through wires to represent letters and numbers—usually in Morse code (dots and dashes).
:gear: How Does the Circuit Work?
A basic telegraph circuit includes:
  1. Power source – Like a battery.
  2. Telegraph key – A simple switch that the operator presses to complete the circuit.
  3. Wire – To carry the electrical current.
  4. Electromagnet – Becomes magnetized when current flows through it.
  5. Receiver (Sounder or Buzzer) – Clicks or buzzes to indicate signal.
:counterclockwise_arrows_button: Working Principle:
  • When you press the telegraph key, it closes the circuit, allowing electricity to flow.
  • The current powers an electromagnet at the receiving end.
  • The electromagnet pulls a metal armature, creating a click or sound.
  • By pressing the key for different durations, you create short (dots) and long (dashes) signals for Morse code.
  • Releasing the key opens the circuit, stopping the current and demagnetizing the coil.
:wrench: How to Build a Simple Telegraph Circuit
:toolbox: Components:
  • 1x 9V Battery
  • 1x Telegraph Key (or a push button)
  • 1x Buzzer or Electromagnet and Metal Arm
  • Wires
  • (Optional) Light bulb or LED to visualize signal
