Encender motor 1, al apagar motor 1 el temporizador a determinado tiempo activa motor 2
This idea describes an automatic motor control circuit using a timer. The concept is as follows:
- Motor 1 starts when the circuit is activated.
- When Motor 1 turns off, a timer begins counting a predetermined delay.
- After the set time, the timer activates Motor 2 automatically.
Possible Circuit Implementation:
- Using a Relay & Timer (555 Timer or Delay Relay):
- A relay can control the switching between Motor 1 and Motor 2.
- A 555 timer in monostable mode can introduce the delay before Motor 2 turns on.
- Alternatively, a programmable microcontroller (Arduino, PIC, ESP8266, etc.) can handle timing and control logic.
Would you like a circuit diagram or a specific implementation idea?
