Basic manipulation needs improvement
Major needs for improvement:
  1. Select & stretch items/wires, and have the wires stay connected correctly.
  2. Mirror or rotate entire selection.
  3. Select multiple wires, and change color at once.
  4. More colors.
  5. Wire gauges and simulated wire temperatures.
  6. Fix screen freezing problem, where all unsaved work gets lost.
I’ve programmed my one simulator app and it has these basic features, but overall dcaclab is much better while being too restricted at the same time.
Hi @cteas , thanks for your valuable suggestions. As for screen freezing, is there specific circuit that triggers the issue? How often does this issue happen?
Also as for requesting more colors, can you please explain the case that requires more colors to pick from? Do you mean for bulbs or more colors for wires ? More details would be appreciated :+1:
Thanks again for your notes :slightly_smiling_face:
We just applied this feature : )
https://x.com/DCACLab/status/1987129782778155184?s=20
