Astable Mode 555 Timer Calculation in DCAClab
1. Frequency of Oscillation (f):
The formula for frequency is:
f = 1.44 / (R1 + 2R2) * C1
Substitute the given values:
f = 1.44 / (20,000 + 2 * 20,000) * 0.01 * 10^(-6)
Simplifying:
f = 1.44 / (60,000 * 0.01 * 10^(-6))
f = 1.44 / 0.0006
f = 2400 Hz
So, the frequency is 2400 Hz (or 2.4 kHz).
2. High Time (T_high):
The formula for high time is:
T_high = 0.693 * (R1 + R2) * C1
Substitute the values:
T_high = 0.693 * (20,000 + 20,000) * 0.01 * 10^(-6)
T_high = 0.693 * 40,000 * 0.01 * 10^(-6)
T_high = 0.693 * 0.0004
T_high = 0.0002772 seconds = 277.2 ÎĽs
So, the high time is 277.2 ÎĽs.
3. Low Time (T_low):
The formula for low time is:
T_low = 0.693 * R2 * C1
T_low = 0.693 * 20,000 * 0.01 * 10^(-6)
T_low = 0.693 * 0.0002
T_low = 0.0001386 seconds = 138.6 ÎĽs
So, the low time is 138.6 ÎĽs.
4. Duty Cycle (D):
The duty cycle formula is:
D = (T_high / (T_high + T_low)) * 100
D = (277.2 ÎĽs / (277.2 ÎĽs + 138.6 ÎĽs)) * 100
D = (277.2 / 415.8) * 100
D = 66.67%
So, the duty cycle is 66.67%.
For learning you can visit-
In astable mode, the 555 timer continuously switches between HIGH and LOW states based on the charging and discharging of the capacitor through the resistors. The frequency and duty cycle depend on the values of R1, R2, and C. Adjusting these components allows you to control the output waveform timing precisely.
Hi @sukhkaur95173
Yes, you are absolutely right.
In astable mode, the 555 timer acts as a “free-running” oscillator. This means it doesn’t need an external trigger to change states; it just keeps flipping between HIGH and LOW on its own.
Here is a simple breakdown of how those components work together:
  • Charging (HIGH): The capacitor charges through both R1 and R2. This sets how long the pulse stays “on.”
  • Discharging (LOW): The capacitor discharges only through R2. This sets how long the pulse stays “off.”
  • The Result: By changing the values of R1, R2, or the capacitor (C), you change how fast the cycle repeats (frequency) and the percentage of time the signal stays HIGH (duty cycle).
If you learn about more circuits simulation in DCAClab, you can visit my profile.
https://dcaclab.com/users/28506/profile
