555 Timer IC Astable Mode Calculation
Simple 555 Timer IC Math Calculation in Astable Mode:
In the given circuit, the values of the components are:
  • R1 = 1K (1000 Ohms)
  • R2 = 100K (100,000 Ohms)
  • C1 = 10uF (0.00001 Farads)
Let’s calculate the key time parameters for the 555 timer in astable mode.
  1. Time High (T1) is the duration when the output is high (5V). The formula to calculate it is:
    T1 = 0.693 × (R1 + R2) × C1
    Substituting the values:
    T1 = 0.693 × (1000 + 100000) × 0.00001 = 0.699 seconds
    So, T1 = 699 milliseconds.
  2. Time Low (T2) is the duration when the output is low (0V). It can be calculated with the formula:
    T2 = 0.693 × R2 × C1
    T2 = 0.693 × 100000 × 0.00001 = 0.693 seconds
    So, T2 = 693 milliseconds.
  3. Time Period (T) is the total time of one complete cycle (high + low). It is the sum of T1 and T2, or it can be calculated using:
    T = 0.693 × (R1 + 2 × R2) × C1 or T = T1 + T2
    T = 0.693 × (1000 + 2 × 100000) × 0.00001 = 1.393 seconds
    So, T = 1.393 seconds.
  4. Frequency (F) is the reciprocal of the time period:
    F = 1.44 / (R1 + 2 × R2) × C1 or F = 1 / T
    F = 1.44 / (1000 + 2 × 100000) × 0.00001 = 0.718 Hertz
    So, F = 0.718 Hz.
  5. Duty Cycle is the percentage of time the output is high during the period. It can be calculated as:
    Duty Cycle = (T1 / T) × 100
    Duty Cycle = (0.699 / 1.393) × 100 = 50.249%
    So, Duty Cycle = 50.249%.
This is how you can calculate the time high, time low, period, frequency, and duty cycle for a 555 timer in astable mode based on given resistor and capacitor values. Using a 555 timer calculator can simplify these calculations when designing circuits for projects.
